[Gdal-dev] Copying meta data
Fri Nov 17 19:23:10 EST 2006
Matt Hanson wrote:
> Are GDALDataset and GDALPamDataset fairly interchangeable?  Would it be as
> simple as changing the base classes to turn on support for PAM ?
Matt,
GDALDataset is a base class for GDALPamDataset.  You will need to include
gdal_pam.h (where gdal_priv.h was normally included).  But yes, it should
generally be sufficient to change which case you use as a base class for
your format specific dataset and band classes.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
