[Gdal-dev] Copying meta data
Ivan Lucena
ILucena at clarku.edu
Fri Nov 17 15:53:58 EST 2006
Frank,
Sorry for my ignorance in this matter, but where can I found the full
description (documentation) for the "aux.xml"?
Thanks in advance.
Ivan
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank
Warmerdam
Sent: Friday, November 17, 2006 6:55 PM
To: Matt Hanson
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Copying meta data
Matt Hanson wrote:
> Ok, good to know. I'm currently using ENVI as an output file now, but
one
> of my colleagues had written a driver for our own format I haven't
tested
> yet. Hopefully it supports writing metadata.
> So if I set GDAL_PAM_ENABLED then when I call SetMetaData,
SetGeoTransform,
> or SetProjectionRef, then it will automatically just output it to an
aux.xml
> file? If I have GDAL_PAM_ENABLED set to no then will it generate an
error?
Matt,
Well, whether an error will actually be generated or not, I'm not so
sure.
Generally SetMetadata() never fails because the default implementation
is
to dump the metadata into the base class datastructure for metadata, but
the
metadata will not get written to disk.
I would also note that the GDAL_PAM_ENABLED flag only affects drivers
that
have been updated to support the PAM mechanism. This includes most core
drivers but if you have written your own format driver, and it does not
derive the classes from GDALPamDataset and GDALPamRasterBand then the
PAM
mechanism will likely *not* work for your driver.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo,
http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
