[Gdal-dev] Gdalwarp resolution
Sampson, David
dsampson at NRCan.gc.ca
Wed Nov 22 16:14:56 EST 2006
Frank,
Thanks for the suggestion for down sampling....
I think I am confused or trying to do too much... this is my CLI call
gdal_translate -gcp 378.19 196.43 -76.777261 45.67899 -gcp 6013.13
282.36 -76.744739 45.678655 -gcp 5890.36 7537.81 -76.745361 45.649344
-gcp 279.98
7464.15 -76.777866 45.649679 -scale -ot byte -a_srs EPSG:4201 -outsize
37.5% 37.5% -mo TIFFTAG_XRESOLUTION=300 -mo TIFFTAG_YRESOLUTION=300 -mo
"Area_or_Point = Area" A38_001.tif oA38_001.tif
however I have the same issue as I outlined in MSG [Gdal-dev]
Gdal_translate. Scaling, sizing, georeferencing
the issue that I assume that after the above I should have a
geo-referenced image. Two images side by side should overlap 60%
When I compare with a photo of same area processed using an older script
in Open EV the old images overlap, and the new gdal_translate images are
simply SMALLER pictures. The goal is for me to duplicate these
previously geo-refed images. Both the new and old images line up for the
Upper left corner, but then it falls apart. What happened to the other
three control points I passed it? A smaller resolution image should
occupy the same physical space, right?
Some other posts have asked the same question but I never find the
answer.
As a final product I will be using a -outsize of 25% or 66.7% whatever
resolution they come out as.
The solution I have come across is the following.
1.
-gcp 279.98
7464.15 -76.777866 45.649679 -scale -ot byte -a_srs EPSG:4201 -mo
2.
gdalwarp -tr 0.0000116774 -0.0000082992 oA38_001.tif RoA38_001.tif
For this second stage I took info from gdalinfo of an image from step
one using the 67%. I passed that image through gdalwarp without options
to set the GCP's to the UL LL etc etc. I took the resolution and
multiplied in by 1.33. I guess I am not achieving a 300 dpi image after
all, but I got the file size I am looking for.
So these new resolution factors were passed again on the same image from
step one and it seemed to work. But it is messy and I can't evaluate
each photo.
The end result with this two step process is a geo-refed image that is
the same size that I am trying to duplicate and matches all four
corners.
Unfortunately I partialy don't realy know what all is ahppening or how I
could have predicted this outcome.
How can I get to the final product quicker and cleaner?
Did I goof somewhere along the way?
As usual, thanks
Cheers
If you just want to downsample the image, you could try:
gdal_translate -outsize 37.5% 37.5% in.tif out.tif
If you also want to override the resolution metadata tags (possibly
necessary to make printing software print properly) try:
gdal_translate -outsize 37.5% 37.5% \
-mo TIFFTAG_XRESOLUTION=300 -mo TIFFTAG_YRESOLUTION=300 \
in.tif out.tif
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Sampson, David
Sent: November 22, 2006 09:52
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Gdalwarp resolution
Hey folks,
I am trying to move a 800 dpi to a 300 dpi image. The src image was
created using gdal_translate to assign SRS, 4 GCP's and change from
16bit to 8bit image. Src image has the following meta_tags
Metadata:
AREA_OR_POINT=Area
TIFFTAG_XRESOLUTION=800
TIFFTAG_YRESOLUTION=800
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Area_or_Point =Area
The command line I am using is:
gdalwarp -tr 300 300 oA38_001.tif S_A38_001.tif
But I get this error
Creating output file that is 0P x 0L.
ERROR 1: Attempt to create 0x0x1 TIFF file, but width, height and bands
must be positive.
Any ideas?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061122/0093a2b4/attachment.html
