[Gdal-dev] LOCALE dependent segfault in OGR
Markus Neteler
neteler at itc.it
Wed Nov 22 10:54:54 EST 2006
after a new installation of Mandriva 2007 I found some fancy bug (or whatever),
apparently related to the LOCALE:
1. DE LOCALE:
GRASS 6.3.cvs (eu_laea):~/data/vmap0_europe_shape > v.in.ogr europe_countries_LAEA.shp out=europe_countries --o
WARNUNG: Die Vektorkarte 'europe_countries' existiert bereits und wird
überschrieben.
A datum name etrs89 (European_Terrestrial_Reference_System_1989) was specified without transformation parameters.
Note that the GRASS default for etrs89 is towgs84=0.000,0.000,0.000.
Die Projektionsinformationen des Eingabedatensatzes und der aktuellen Location stimmen überein.
Fahre mit dem Import fort...
überschrieben.
Layer: europe_countries_LAEA
WARNUNG: Spaltenname 'cat' wurde in 'cat_' geändert.
Importiere 3356 Objekte der Karte...
Speicherzugriffsfehler
-> "Segmentation fault"
2. Switching LOCALE:
GRASS 6.3.cvs (eu_laea):~/data/vmap0_europe_shape > export LANGUAGE=en_US
GRASS 6.3.cvs (eu_laea):~/data/vmap0_europe_shape > export LANG=en_US
GRASS 6.3.cvs (eu_laea):~/data/vmap0_europe_shape > export LC_ALL=en_US
WARNING: The vector 'europe_countries' already exists and will be
overwritten.
Projection of input dataset and current location appear to match.
Proceeding with import...
overwritten.
WARNING: Table 'europe_countries' linked to vector did not exist.
WARNING: Column name changed: 'cat' -> 'cat_'
Importing map 3356 features...
Building topology ...
3360 primitives registered
Building areas: 100%
3352 areas built
3329 isles built
Attaching islands: 17%
-> works.
############ System
uname -a
Linux localhost 2.6.17-5mdv #1 SMP Wed Sep 13 14:32:31 EDT 2006 i686 Intel(R) Pentium(R) 4 CPU 2.53GHz GNU/Linux
gcc -v
Using built-in specs.
Target: i586-mandriva-linux-gnu
Configured with: ...
gcc version 4.1.1 20060724 (prerelease) (4.1.1-3mdk)
############# Debugging in gdb:
Back to DE LOCALE:
gdb `which v.in.ogr`
GNU gdb 6.3-8mdv2007.0 (Mandriva Linux release 2007.0)
This GDB was configured as "i586-mandriva-linux-gnu"...Using host libthread_db library "/lib/i686/libthread_db.so.1".
(gdb) r europe_countries_LAEA.shp out=europe_countries --o
Starting program: /home/neteler/soft/63grass_cvsexp/dist.i686-pc-linux-gnu/bin/v.in.ogr europe_countries_LAEA.shp out=europe_countries --o
Reading symbols from shared object read from target memory...done.
Loaded system supplied DSO at 0xbfffe000
[Thread debugging using libthread_db enabled]
[New Thread -1224276272 (LWP 14949)]
Detaching after fork from child process 14952.
Detaching after fork from child process 14953.
überschrieben.
Detaching after fork from child process 14954.
überschrieben.
Detaching after fork from child process 14955.
Detaching after fork from child process 14956.
WARNUNG: Table 'europe_countries' linked to vector did not exist.
Detaching after fork from child process 14957.
Detaching after fork from child process 14958.
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1224276272 (LWP 14949)]
0xb7cdded9 in OGRSpatialReference::Release (this=0x8073948) at ogrspatialreference.cpp:399
399 delete this;
Current language: auto; currently c++
(gdb) bt full
#0 0xb7cdded9 in OGRSpatialReference::Release (this=0x8073948) at ogrspatialreference.cpp:399
No locals.
#1 0xb7cd37af in ~OGRGeometry (this=0x80818e0) at ogrgeometry.cpp:204
No locals.
#2 0xb7cd0ff3 in ~OGRPolygon (this=0x80818e0) at ogr_geometry.h:556
No locals.
#3 0xb7cd7c31 in ~OGRFeature (this=0x8080070) at ogrfeature.cpp:188
No locals.
#4 0xb7cd6755 in OGR_F_Destroy (hFeat=0x8080070) at ogrfeature.cpp:250
No locals.
#5 0x0804d5dc in main (argc=4, argv=0xbfa2c474) at main.c:748
i = Variable "i" is not available.
I updated from GDAL-CVS a few minutes ago. The bt result doesn't tell me
much unfortunately...
Suggestions are welcome,
Markus
