[Gdal-dev] Motion: To approve RFC 6 - Geometry and Feature style as OGR Special Fields
Daniel Morissette dmorissette at mapgears.com
Mon Nov 27 09:52:02 EST 2006
I'll vote +1.
However, the fact that the special fields take precedence over other
fields with the same names in the data file bugs me a little bit. I do
not have a better suggestion to make, but at a minimum the special field
names and this behavior should be well documented in a prominent place
to avoid users getting caught by this magic.
Perhaps ogrinfo could also be modified to detect this case and issue a
warning if it finds those special fields in a dataset?
Daniel
Frank Warmerdam wrote:
> Folks,
> Fields.
> While I have not done a detailed review of the patch, I'm very pleased with
> the new capability, and the approach taken.  I will take responsibility for
> some post-patch integration testing as well as writing script(s) for the
> test
> suite.
> I'm keen to get this in place with a few days to shake things out before
> the
> first GDAL/OGR 1.4.0 Beta (circa December 1st).
> I'll start voting with a "+1".
> Best regards,
Daniel Morissette
http://www.mapgears.com/
