[Gdal-dev] Motion: To approve RFC 6 - Geometry and Feature style as OGR Special Fields
Tamas Szekeres szekerest at gmail.com
Mon Nov 27 13:04:57 EST 2006
Hi Folks,
Since we have not too much time to waste, according to RFC 1 I declare
that all of the PSC members were give a vote and no -1 were got. I
announce that the proposal was accepted as receiving +3 with the
following voting history:
Frank +1
Daniel +1
Howard +0
Andrey +1
Daniel,
Certainly the OGR SQL documentation (ogr_sql.dox) will be updated
according to these changes. This beaviour (that the special field
supersedes the original with the same name) is the same as FID behaves
in the current implementation.
This RFC did not address to change any of the existing applications
like ogrinfo and I think it would not give us more help than reading
the docs carefully. Currently the possibility that FID conflicts is
much higher than the newly introduced OGR_ prefixed fields.
But hopefully implementing an alias functionality would help to handle
this issue properly.
Best Regards,
Tamas Szekeres
2006/11/27, Andrey Kiselev <dron at ak4719.spb.edu>:
> > Fields.
> > While I have not done a detailed review of the patch, I'm very pleased
> > with the new capability, and the approach taken.  I will take
> > responsibility for some post-patch integration testing as well as
> > writing script(s) for the test suite.
> > I'm keen to get this in place with a few days to shake things out
> > before the first GDAL/OGR 1.4.0 Beta (circa December 1st).
> +1
> Best regards,
> Andrey
> Andrey V. Kiselev
> ICQ# 26871517
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
