[Gdal-dev] Motion: To approve RFC 6 - Geometry and Feature
styleas OGR Special Fields
Chapman, Martin
MChapman at sanz.com
Mon Nov 27 18:32:08 EST 2006
I vote yes.
Martin Chapman
Software Developer
http://www.earthwhere.com
W - 303.495.6326
C - 303.898.0397
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Tamas Szekeres
Sent: Monday, November 27, 2006 11:05 AM
To: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Motion: To approve RFC 6 - Geometry and Feature
Hi Folks,
Since we have not too much time to waste, according to RFC 1 I declare
that all of the PSC members were give a vote and no -1 were got. I
announce that the proposal was accepted as receiving +3 with the
following voting history:
Frank +1
Daniel +1
Howard +0
Andrey +1
Daniel,
Certainly the OGR SQL documentation (ogr_sql.dox) will be updated
according to these changes. This beaviour (that the special field
supersedes the original with the same name) is the same as FID behaves
in the current implementation.
This RFC did not address to change any of the existing applications
like ogrinfo and I think it would not give us more help than reading
the docs carefully. Currently the possibility that FID conflicts is
much higher than the newly introduced OGR_ prefixed fields.
But hopefully implementing an alias functionality would help to handle
this issue properly.
Best Regards,
Tamas Szekeres
2006/11/27, Andrey Kiselev <dron at ak4719.spb.edu>:
> On Sun, Nov 26, 2006 at 08:08:28PM -0500, Frank Warmerdam wrote:
> > Motion: To approve RFC 6 - Geometry and Feature style as OGR Special
> > Fields.
> > While I have not done a detailed review of the patch, I'm very
pleased
> > with the new capability, and the approach taken. I will take
> > responsibility for some post-patch integration testing as well as
> > writing script(s) for the test suite.
> > I'm keen to get this in place with a few days to shake things out
> > before the first GDAL/OGR 1.4.0 Beta (circa December 1st).
> +1
> Best regards,
> Andrey
> Andrey V. Kiselev
> ICQ# 26871517
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
