[Gdal-dev] problem with polygonz shapefile and ArcExplorer ...
LALLAURET Fabrice - <SSII>
fabrice.lallauret at thalesgroup.com
Thu Nov 30 04:57:06 EST 2006
I have a problem with the shapefile driver in the 1.3.2 release of OGR.
The shapefiles seems good with ArcMap or ogrinfo but can't be display
with ArcExplorer 9.1 (Linux & windows)
(the console of ArcExplorer display the following message : > Nov 29,
2006 6:28:41 PM: com.esri.mo.file.shp.db
com.esri.mo.file.shp.InvalidShapeException: 1 invalid shape/s were
detected in ...)
I've tried with ogr 1.3.1 and it works.
The problem seems to be the addition of the "bMeasureIsUsed" in the
shpopen.c file. When I force it to TRUE, the generated shapefile can be
succefully display in ArcExplorer.
Why this flag act on SHPT_POLYGONZ type ?
I have attached to create a small shapefile which I can't display on
ArcExplorer
Regards
.--. Fabrice LALLAURET - PSV Team
|o_o | Tel: (33) (01 34) 22 84 33
|:_/ | Thales Training & Simulation
// \ \ 1, rue du General de Gaulle
(| | ) Z.I. les beaux soleils
/'\_ _/`\ Osny. B.P. 226
\___)=(___/ 95523 Cergy-Pontoise Cedex
E-mail: fabrice.lallauret at thalesgroup.com
"Power corrupts. PowerPoint corrupts absolutely."
My personnal (french) Websites: http://www.xbee.net
and http://www.french-comics-zone.fr.st
#include "ogrsf_frmts.h"
#include "cpl_conv.h"
#include "cpl_string.h"
/* main() */
int main( int nArgc, char ** papszArgv )
const char *pszFormat = "ESRI Shapefile";
const char *pszOutputName = "test.shp";
OGRRegisterAll();
OGRDataSource *poDstDS;
OGRLayer *poDstLayer = NULL;
OGRSFDriverRegistrar *poR = OGRSFDriverRegistrar::GetRegistrar();
OGRSFDriver *poDriver = NULL;
int iDriver;
for( iDriver = 0;
iDriver < poR->GetDriverCount() && poDriver == NULL;
iDriver++ )
if( EQUAL(poR->GetDriver(iDriver)->GetName(),pszFormat) )
poDriver = poR->GetDriver(iDriver);
poDstDS = poDriver->CreateDataSource( pszOutputName, NULL );
OGREnvelope sExtents;
OGRPolygon oRegion;
OGRLinearRing oRing;
oRing.addPoint( -1.0, -1.0 , 0.0 );
oRing.addPoint( -1.0, 1.0 , 0.0 );
oRing.addPoint( 1.0, -1.0 , 0.0 );
oRing.addPoint( 9.080074, 52.269425, 0.000000 );
oRing.addPoint( 9.080936, 52.268975, 0.000000 );
oRing.addPoint( 9.081471, 52.269088, 0.000000 );
oRing.addPoint( 0.0, 0.0 , 0.0 );
oRing.addPoint( 0.0, 0.1 , 0.0 );
oRing.addPoint( 0.1, 0.0 , 0.0 );
oRegion.addRing( &oRing );
poDstLayer = poDstDS->CreateLayer( "tileindex" );
OGRFeature oTileFeat( poDstLayer->GetLayerDefn() );
oTileFeat.SetGeometry( &oRegion );
if( poDstLayer->CreateFeature( &oTileFeat ) != OGRERR_NONE )
printf( "Failed to create feature on tile index ... terminating." );
delete poDstDS;
exit( 1 );
delete poDstDS;
return 0;
