[Gdal-dev] gdal_grass.dll
Thu Nov 30 09:21:22 EST 2006
Radim Blazek wrote:
> Hi.
> Where should we place the gdal_grass.dll so that gdal can find it
> and register?
Radim,
Looking at the code, it would appear that you can out plugins in a
gdalplugins subdirectory of whatever directory the current executable
comes from.  If you want to put it somewhere else, you will need to
define the GDAL_DRIVER_PATH environment variable or config variable
to point to the directory to be searched.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
