[Gdal-dev] Error making GDAL CVS daily "snapshot"
Frank Warmerdam
warmerdam at pobox.com
Thu Nov 30 19:32:21 EST 2006
Bill Thoen wrote:
> Apparently lidn is a curl thing. I tried ./configure --without-curl, but
> that didn't work. Then I tried removing $(CURL_LIB) from the LIBS list in
> GDALmake.opt, and that didn't work because several other things wanted to
> reference those libraries. SO I finally uninstalled curl, and probably broke
> a bunch of other stuff in OpenOffice (sigh! 'yum remove' seems to be very
> thorough) but then GDAL built just fine.
Bill,
Configuring --without-curl should have fixed the problem, but after
changing your configuration it is generally necessary to do a
manual "make clean" before you rebuild.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
