[Gdal-dev] Where does the CPLError list get freed?
Craig Miller
craig.miller at spatialminds.com
Wed Oct 11 20:44:12 EDT 2006
I'm on the warpath to get rid of a few niggling memory leaks that I'm
detecting. A couple of items have me a bit puzzled at this point and I was
hoping to get a bit of clarification.
1. If I call CPLGetLastErrorMsg() when there is no error, it obtains a
CPLErrorContext via CPLGetErrorContext() which creates an empty
CPLErrorContext and adds it to the list if it doesn't exist. I've looked a
fair amount now, but can't seem to locate where this memory gets freed.
2. Does CPLErrorReset clobber any szLastErrMsg that may have already been
assigned?
* Erase any traces of previous errors.
* This is normally used to ensure that an error which has been recovered
* from does not appear to be still in play with high level functions.
void CPL_STDCALL CPLErrorReset()
CPLErrorContext *psCtx = CPLGetErrorContext();
psCtx->nLastErrNo = CPLE_None;
psCtx->szLastErrMsg[0] = '\0';
psCtx->eLastErrType = CE_None;
Here is the stack trace showing where the memory is being allocated that
isn't being freed.
Call Stack:
c:\vault\gdal\port\cpl_vsisimple.cpp (323): VSICalloc
c:\vault\gdal\port\cpl_conv.cpp (240): CPLCalloc
c:\vault\gdal\port\cpl_error.cpp (122): CPLGetErrorContext
c:\vault\gdal\port\cpl_error.cpp (436): CPLGetLastErrorMsg
c:\vault\freeworlddesktop\geolib\geodatabase.cpp (53):
CGeoDatabase::SetConnection
Line 53 of CGeoDatabase::SetConnection is:
const char* errMsg = CPLGetLastErrorMsg();
CPLErrorReset() is called 2 lines later.
The documentation for CPLGetLastErrorMsg indicates that the string returned
should not be freed by the caller.
Thanks for any pointers (pun intended). :-) I appreciate the help.
--Craig
