[Gdal-dev] no sucess trying to build ECW for GDAL
Eduardo Patto Kanegae epk.lists at gmail.com
Wed Oct 18 11:06:49 EDT 2006
Hi folks, thanks for the tips.
Now I got sucess on Fedora 5 ( which GCC 4 is default, but GCC 3 is
available also)
with:
$ CC=/usr/bin/gcc32 CXX=/usr/bin/gcc32 ./configure
$ make
$ make install
I didn't build MapServer or any other viewer yet to check is this library
was really setup with sucess, but if I found any other problems, I'll post
here.
Thanks
Eduardo
On 10/4/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Folks,
> All I would add is that I've now built the new libecw with gcc 3.3.3 and
> it seems to build, and install fine.  I build GDAL against it with no
> problem
> and the ecw.py autotest passes.  This on Intel Linux.
> Perhaps a brief beta cycle before final release could have identified the
> problems with newer gcc's!
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
http://www.webmapit.com.br
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061018/93d1fd98/attachment.html
