[Gdal-dev] Visual Studio 2005, GDAL and Manifests
Simon Perkins sy at perkins.net
Sun Oct 22 23:41:37 EDT 2006
Hi GDALers,
After bashing my head against the brick wall that is Visual Studio 2005
for most of the day, I made a discovery that I figured I'd share with
you guys to perhaps save some of you the same headaches...
The problem I have been getting is that I've been unable to compile
applications in Visual Studio 2005 using the /MDd compile switch (link
with the debug C runtime), when I link them against the GDAL library
compiled with the /MD switch (link with the non-debug CRT, which is what
the GDAL makefiles do). Doing this results in a "MSVCR80.DLL not found"
error when I try to run the program. Compiling my code with /MD fixes
things, but this is not the default for Visual Studio debug builds, and
simply changing the switch to /MD breaks other things in the debug
build. Trying to copy the MSVCR80.DLL file that comes with Visual Studio
into my program's folder changes the error to "an application tried to
load the C runtime incorrectly".
Officially, mixing code that uses /MDd with libraries that use /MD is
not supported, so you won't find much help in the MS documentation. In
practice however, this combination is almost impossible to avoid this if
you use third party DLLs such as GDAL (often only available built with
/MD) with your own code in the Visual Studio IDE. Anyway, after much
searching and experimentation, I found the answer.
You MUST embed the manifest file that is generated by the GDAL
compilation process into the GDAL DLL. It is NOT enough to simply have
the gdal13.dll.manifest file in the same directory as the DLL.
Previously I thought this was enough (and I updated the makefile.vc
files to install this manifest file), but it isn't.
To embed the manifest use, the mt.exe tool:
 > mt -manifest gdal13.dll.manifest -outputresource:gdal13.dll;2
Probably the makefile.vc files should be updated to do this. I'll
hopefully get to it in a few days time if nobody beats me to it...
Cheers,
Sy
