[Gdal-dev] Dissolving internal boundaries
matt.pettis at thomson.com matt.pettis at thomson.com
Mon Oct 23 14:02:58 EDT 2006
Is there any way with gdal/ogr tools to join polygons into a single
polygon based upon a .dbf attribute and dissolve the interior boundaries
of constituent shapefile polygons?  I created an ascii visual at the
bottom to describe what I want if the verbage is not clear.
thanks,
matt
Before:
|  Polygon 1         |
| Polygon 2  | Polygon 3    |
After:
|   Joined Region    |_______
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061023/d4c678db/attachment.html
