[Gdal-dev] -spat switch in ogr2ogr
Frank Warmerdam
warmerdam at pobox.com
Wed Oct 25 00:20:23 EDT 2006
Brian Timoney wrote:
> All:
> At the risk of disproving the adage that the only dumb question is the
> one left unasked, I'm having some trouble applying the -spat switch
> using ogr2ogr from the command line.
> I have a table of US cities in PostGIS called..."cities" in lat/long NAD
> 83 (EPSG:4269)
> I want to pull cities from the middle of the country from a BBOX of
> (-114,30,-100,45) and throw them into a new shapefile.
> So I hazarded...
> ogr2ogr mid_city.shp PG:'dbname=mydb user=me' cities -spat '-114 30 -100
> 45'
> No dice (empty shapefile). There are 75+ features that fall inside the
> bounding box.
> I've also tried double quotes and no quotes around the xmin ymin xmax
> ymax values.
Brian,
It should work with:
ogr2ogr mid_city.shp PG:'dbname=mydb user=me' cities -spat -114 30 -100 45
Would it be fair for me to guess that the following works fine?
So if my suggested approach (no quotes on -spat argument) doesn't work, then
I'm at a bit of a loss. I guess I'd have to actually test things at my end!
By the way, you might want to set the CPL_DEBUG environment variable to ON.
This will produce various debug output of the actual SQL being sent to
postgis. This might give clues.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
