[Gdal-dev] Get Line Length
Thu Oct 26 12:30:34 EDT 2006
Rob McCulley wrote:
> Hi All,
> I’m trying to write a script that will calculate the total length of a
> polyline shapefile using ogr in python.  I see in the ogr documentation
> that both the OGRCurve and OGRLineString class support the method
> get_Length().  The problem I’m having is that I can’t figure out how to
> get a linestring or curve object.  Here  is what I have so far:
> shp = ogr.Open(gpsfilelocation)
> lyr = shp.GetLayer()
> totalLength = 0
> for i in range(lyr.GetFeatureCount()):
>             ftr = lyr.GetFeature(i)
>             geom = lyr.GetGeometryRef()
>             length = ?
>             totalLength = totalLength + length
> At this point I could iterate through the points of the geometry and
> calculate the length of each segment, but using a get_Length() function
> seems much more elegant.
Rob,
I'm afraid that get_Length() is not currently exposed to python.
The python (and other mapscript bindings and OGR C API) arranged
such that you work only with OGRGeometry handles - you can't turn
these into specific geometry classes though underneath they are
of course of a particular class.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
