[Gdal-dev] SDE Driver Change
Christian Ratliff
Christian.Ratliff at delorme.com
Thu Oct 26 13:23:59 EDT 2006
During the QA process for our product, we noticed polygons were being
read from ARC/SDE with a reversed (left hand) winding. This results in
isClockwise() returning the wrong value for all such polygons. I
updated the SDE driver with the change indicated below and then
re-tested SDE and non-SDE data sources. Everything looks good now:
src/ogr/ogrsf_formats/sde/ogrsdelayer.cpp
719c723
< nSDEErr = SE_shape_get_all_points( hShape, SE_DEFAULT_ROTATION,
> nSDEErr = SE_shape_get_all_points( hShape, SE_RIGHT_HAND_ROTATION,
christian
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061026/996b4da9/attachment.html
