[Gdal-dev] ogr2ogr Unable to open datasource
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue Oct 31 12:49:00 EST 2006
AFAIK, in order to get a shapefile with the actual geometry, you would
need to use the VRT driver on the CSV file:
http://www.gdal.org/ogr/drv_vrt.html
Best regards,
Bart
Ryan Ollerenshaw schreef:
> Bart van den Eijnden (OSGIS) wrote:
>> Your filename extension is cvs, are you sure it should not be csv?
>> Best regards,
>> Bart
> Yes it did just appear to be a typo,But i am running into a new
> problem, the command:
> ogr2ogr -f "ESRI Shapefile" thick18.shp thick18_test.csv
> only seems to create a dbf file, why is there no shp file created?
>>> I keep getting the following error:
>>> $ ogr2ogr -f "ESRI Shapefile" thick18.shp thick18_test.cvs
>>> FAILURE:
>>> Unable to open datasource `thick18_test.cvs' with the following
>>> drivers.
>>> -> ESRI Shapefile
>>> -> MapInfo File
>>> -> UK .NTF
>>> -> SDTS
>>> -> TIGER
>>> -> S57
>>> -> DGN
>>> -> VRT
>>> -> AVCBin
>>> -> REC
>>> -> Memory
>>> -> CSV
>>> -> GML
>>> -> PostgreSQL
>>> My CSV file looks like this:
>>> -180,90.00,0.00,4.84
>>> -179,90.00,0.00,4.84
>>> -178,90.00,0.00,4.84
>>> -177,90.00,0.00,4.84
>>> -176,90.00,0.00,4.84
>>> -175,90.00,0.00,4.84
>>> I am not sure why i am getting an unable to open datasource, any
>>> ideas on what i could be doing wrong would be much appreciated.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
