[Gdal-dev] ogr2ogr Unable to open datasource
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 31 13:03:56 EST 2006
Ryan Ollerenshaw wrote:
> Bart van den Eijnden (OSGIS) wrote:
>> Your filename extension is cvs, are you sure it should not be csv?
>> Best regards,
>> Bart
> Yes it did just appear to be a typo,But i am running into a new problem,
> the command:
> ogr2ogr -f "ESRI Shapefile" thick18.shp thick18_test.csv
> only seems to create a dbf file, why is there no shp file created?
Ryan,
Because as far as OGR knows the csv file is non-spatial, so when it creates
the "shapefile" it just creates the .dbf file and no spatial files.
If you want to treat the first two columns as a point location you need to
follow extra steps (ie. using an OGR VRT file) to turn them into a spatial
location.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
