[Gdal-dev] Enabling Xerces support
Ryan Ollerenshaw
ollerery at engr.orst.edu
Thu Sep 14 15:33:02 EDT 2006
Ryan Ollerenshaw wrote:
> I have seen a few threads on this but they all seem to say that
> version 1.7 is needed but i can no longer find this version of the
> Xerces site, only 2.7 is available. I am using the following
> configure command
> > ./configure --with-xerces
> but when i do this i get the following error:
> checking for Xerces C++... requested, but compile or link fails!
> g++ -I/usr/local/include -I/usr/local/include/xercesc -o conftest
> conftest.cpp -L/usr/local/lib -lxerces-c -lpthread -ljpeg -ltiff -lpng
> -lpq -L/usr/lib -lpq -lz
> -lm -lrt -ldl
> /usr/bin/ld: cannot find -lxerces-c
> I have complied xerces-c-src_2_7_0 from the source in the directory
> /root/xerces-c-src_2_7_0/
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Sorry for the post looks like i was just not following direction. The
install of Xerces-C works just fine with gdal when you follow the
directions the the Xerces site:
http://xml.apache.org/xerces-c/build-winunix.html#UNIX
built gdal with:
./configure --with-xerces=/path/to/xerces-c-src_2_7_0/
