[Gdal-dev] GDAL-Building
Frank Warmerdam
warmerdam at pobox.com
Tue Sep 19 14:20:02 EDT 2006
kiruba nantham wrote:
> i am building gdal-1.3.2 using embedded VC++ 4.0 when i am compiling
> it i am getting 95 errors (error is : can not open include file: '
> errno.h ' : no such file or directory). what directory i should include
> for this errno.h?
Kiruba,
VC++ 4.0? Whew, that seems pretty ancient. I think VC6 would be the
oldest MS compiler likely to work.
> otherwise if any one knows how to build gdal13.dll using cygwin
> please tell me how to do? i tried with cygwin it's creating
> library(libgdal.a) but it is not creating gdal13.dll.
I'm not sure why you are running into problems with Cygwin. I had thought
this was working ok. But you do need to know that a Cygwin build of the DLL
is not generally going to work smoothly with non-Cygwin components. It's
fine if you want an all-cygwin solution, but you can't necessarily turn around
and use that DLL for non-cygwin purposes.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
