[Gdal-dev] 1.3.2 build error - (linux, --without-libtool, make -j)
Tue Sep 19 16:32:59 EDT 2006
John Johnson wrote:
> When compiling on linux w/o libtool (e.g. to support kakadu), make -j is
> broken.
> Here's a little patch to fix it.
> -------------------- cut --------------------
> diff -uNr gdal-1.3.2.orig/GNUmakefile gdal-1.3.2/GNUmakefile
> --- gdal-1.3.2.orig/GNUmakefile    2006-03-24 08:51:56.000000000 -0800
> +++ gdal-1.3.2/GNUmakefile    2006-09-19 12:25:36.000000000 -0700
> @@ -35,7 +35,7 @@
>      $(AR) r $(GDAL_LIB) $(GDAL_OBJ)
>      $(RANLIB) $(GDAL_LIB)
> -$(GDAL_SLIB):    $(GDAL_OBJ)
> +$(GDAL_SLIB):    $(GDAL_OBJ) $(GDAL_LIB)
>      $(LD_SHARED) $(GDAL_SLIB_SONAME) $(GDAL_OBJ) $(GDAL_LIBS) $(LIBS) \
>          -o $(GDAL_SLIB)
John,
Patch applied.
Thanks!
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
