[Gdal-dev] OGR and python: File creation question...
Aykut KOÇAK
aykutkocak at superonline.com
Tue Sep 26 14:25:10 EDT 2006
Thank you for answer, working for me as well.
Bryan Keith wrote:
> Merhaba Aykut,
> See below.
> Aykut KOÇAK wrote:
>> Hi to all,
>> I am trying the following simple python code to create a ESRI Shape
>> file. This script seems working fine. But when I checked the new file
>> with ogrinfo, I can not see the field I am trying to have within SHP
>> file. What am i doing wrong with this? Thanks in advance for all
>> suggestions.
>> Regards,
>> Python Code:
>> import sys,os
>> # Vector Mapping support
>> import ogr
>> if __name__=="__main__":
>> # Create the driver to use
>> drv=ogr.GetDriverByName("ESRI Shapefile")
>> # Create the DataSource to be written
>> ds=drv.CreateDataSource("test.shp")
>> # Create a layer
>> lyr=ds.CreateLayer(name='test_layer',geom_type=ogr.wkbPoint)
>> # Prepare the structure of the a feature.
>> field_def=ogr.FieldDefn('test1',ogr.OFTInteger)
> At this point in my code that works I have a line like this:
> lyr.CreateField(field_def)
> Hope that helps.
> Bryan
>> feature_def=ogr.FeatureDefn(name='test_feature')
>> feature_def.AddFieldDefn(field_def)
>> feature_def.SetGeomType(ogr.wkbPoint)
>> # Create a feature using prepared structure
>> feature=ogr.Feature(feature_def)
>> # Set the value of the field for this feature
>> feature.SetField(0,173)
>> # Set the Geometry for this feature
>> geom=ogr.CreateGeometryFromWkt('POINT(%f %f)' % (32.0,39.0))
>> feature.SetGeometryDirectly(geom)
>> # Add this new feature to the Layer
>> lyr.CreateFeature(feature)
>> # be sure everything written to disk
>> lyr.SyncToDisk()
>> # Destroy the Data Source
>> ds.Destroy()
>> # exit gracefully
>> sys.exit(0)
>> ogrinfo results:
>> oot at clown-aero:~/project/python# ogrinfo test.shp -al
>> INFO: Open of `test.shp'
>> using driver `ESRI Shapefile' successful.
>> Layer name: test
>> Geometry: Point
>> Feature Count: 1
>> Extent: (32.000000, 39.000000) - (32.000000, 39.000000)
>> Layer SRS WKT:
>> (unknown)
>> FID: Real (11.0)
>> OGRFeature(test):0
>> FID (Real) = 0
>> POINT (32 39)
Aykut KOÇAK
Elektronik Mühendisi
(/Electronics Engineer/)
E-Posta
(/E-Mail/ )
