[Gdal-dev] NITF JPEG Compression
Alan Stewart astewart at TerraGoTech.com
Tue Sep 26 14:54:15 EDT 2006
Frank Warmerdam wrote:
> The jpeg in nitf support was implemented after the 1.3.2 release.  You
> can
> grab a nightly CVS snapshot to test it out.  It should work with either
> the internal libjpeg, or an external one.  No need to alter your
> configuration
> for this.
Thanks, many of the C3-compressed files work with the 2006.09.26 snapshot.
However, I am frequently seeing two JPEG-related errors from gdal_translate:
ERROR 6: SetColorInterpretation() not supported for this dataset.
and
ERROR 1: libjpeg: Unsupported JPEG data precision 12
Also, files where before gdal_translate failed with:
ERROR 1: The file i_3051e.ntf appears to be an NITF file, but no image
blocks were found on it.  GDAL cannot utilize non-image
NITF files.
GDALOpen failed - 1
NITF files.
now cause an abend - Windows asks if you want to report the error to
Microsoft - with:
Warning 1: The file i_3051e.ntf appears to be an NITF file, but no image
ERROR 5: GDALDataset::GetRasterBand(1) - Illegal band #
 Alan Stewart
 Senior Software Architect
 TerraGo Technologies, Inc.
 678-391-9700 x9615
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060926/99f5cacc/astewart.vcf
