[Gdal-dev] NITF JPEG Compression
Frank Warmerdam
warmerdam at pobox.com
Mon Sep 25 18:48:41 EDT 2006
Alan Stewart wrote:
> Frank Warmerdam <warmerdam at pobox.com> wrote:
>> I have committed preliminary support to the GDAL NITF driver for JPEG
>> (C3) compressed images. This includes "single blocked" (one big tile)
>> and
>> multi-blocked images. It only works for 8bit, not 12/16 bit images. It
>> does not (as far as I understand it) support lossly compressed jpeg. The
>> support is read-only, not for export.
>> I am interested in reports of problems with the support.
> I've downloaded and build gdal-1.3.2 on Windows XP. All the JPEG images
> seem to be failing in the sample file set posted at
> <http://www.gwg.nga.mil/ntb/baseline/software/samplefile.html>. For
> example, in the NITF 2.0 section, U_1105A, U_1025A, U_1033A and U_1036A
> fail.
> Should I be using the external JPEG library support I see in nmake.opt?
Alan,
The jpeg in nitf support was implemented after the 1.3.2 release. You can
grab a nightly CVS snapshot to test it out. It should work with either
the internal libjpeg, or an external one. No need to alter your configuration
for this.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
