[Gdal-dev] GDAL and MrSID
Craig
cspeirs at softree.com
Wed Sep 27 14:12:28 EDT 2006
I am new to GDAL and trying to read and display Mr. SID files. I am finding the performance is horrific (2 minutes to read a 7Mb sid image).
I am using RasterIO (see snippet of code below). Setting GDAL_ONE_BIG_READ has no effect. What am I missing? Is there some code somewhere which shows how to read Mr.SID into a raster of RGB triples? Am I better off to user the Mr. SID API directly instead of GDAL?
Thanks in advance.
Craig Speirs
for (int iBand=1,nBandsRead=0;iBand<=nBands; iBand ++)
iColorOffset = 0;
iColorInterp = poDataset->GetRasterBand(iBand)->GetColorInterpretation();
switch(iColorInterp)
case GCI_RedBand : iColorOffset = 2;
break;
case GCI_GreenBand : iColorOffset = 1;
break;
case GCI_BlueBand : iColorOffset = 0;
break;
default : continue ;
gdErr = poDataset->GetRasterBand(iBand)->RasterIO(GF_Read,0,0,
poDataset->GetRasterXSize(), poDataset->GetRasterYSize(),((LPBYTE)pBits) + iColorOffset,bmi.biWidth,abs(bmi.biHeight),GDT_Byte,3,dwBytesPerLine);
nBandsRead ++;
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060927/7f480be3/attachment.html
