[Gdal-dev] some problem on gdal support hdf4 format
Andrey Kiselev andrey.kiselev at gmail.com
Thu Sep 28 05:30:44 EDT 2006
On 9/25/06, xiongfei wen <wxfei19 at yahoo.com.cn> wrote:
> I have downloaded the HDF42r1 from NCSA,I set it in C:/myhdfstuff ,and I can
> access the hdf files using the HDF library,and I change HDF4_DIR and
> HDF4_LIB into
> # Uncomment the following and update to enable NCSA HDF Release 4 support.
> HDF4_DIR = C:\MyHDFStuff\HDF42r1\hdf4lib\debug
> HDF4_LIB = C:\MyHDFStuff\HDF42r1\hdf4lib\debug\lib C:\MyHDFStuff\HDF42r1\hdf4lib\release\lib Ws2_32.lib
You don't need to tuch the HDF4_LIB variable. Just uncomment it and
change a path in HDF4_DIR to point a directory where your HDF library
located (it seems you did right this part).
Regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
