[Gdal-dev] Make error "libtool: compile: unable to infer tagged
configuration"
Mateusz Loskot
mateusz at loskot.net
Sun Apr 1 06:38:32 EDT 2007
Alessandro Amici wrote:
> Frank,
> On Saturday 31 March 2007 20:34, Frank Warmerdam wrote:
>> Possibly we need to regenerate the libtool stuff with a
>> newer version?
> sounds reasonable, since the current version of libtool doesn't have the --tag
> option anymore.
> I would like to have a look at the problema, but ATM i can't checkout from the
> svn:
> $ svn checkout https://svn.osgeo.org/svn/gdal/trunk/gdal gdal
> svn: PROPFIND request failed on '/svn/gdal/gdal/!svn/vcc/default'
> svn: '/svn/gdal/gdal/!svn/vcc/default' path not found
> ^^^^^^^^^ missing 'trunk'?
You need to relocate your working copy because you are using *old* URL
of the repository.
The new URL is:
https://svn.osgeo.org/gdal/
In order to relocate, follow these steps:
1. Go to location where you have trunk checkouted
2. Run
svn switch --relocate https://svn.osgeo.org/svn/gdal/trunk \
https://svn.osgeo.org/gdal/trunk
Cheers
Mateusz Loskot
http://mateusz.loskot.net
