[Gdal-dev] Where's the _gdal module?
Mateusz Loskot
mateusz at loskot.net
Mon Apr 9 11:33:21 EDT 2007
Roger André wrote:
> Ahh, well that may be the crux of the problem. I ran ./configure with no
> options, since I was unsure of what to set.
Roger,
Try to run it this way, to configure the Traditional (for more details,
see the URL below):
./configure --with-python --without-ngpython ...
> Regarding Python support, I don't know what the difference is between SWIG
> and traditional Python support.
Here you can find some explanation:
http://trac.osgeo.org/gdal/wiki/GdalOgrInPython
> I would like to be able to run the
> utilities that come with GDAL, such as "gdal_merge.py".
> It appears that in orger to do this I need to be able to
> import the gdal module. More than that I'm afraid I don't know.
Both bindings are compatible, but I've found the traditional easier to use
because I do not run 'make install' usually, during GDAL development process.
Anyway, you should be able to use both.
> I did find yesterday that there has been some discussion about how Cygwin
> doesn't use shared libraries the way other Unix distros do, and that there
> is a cygMakefile in the gdal/pymod directory. However, it appears to be
> old
> (refers to Python 2.1), and I have no idea how to use it as part of the
> compile process.
Unfortunately, I'm not a user of Cygwin and actually I don't know this file.
The cygMakefile looks to me as a minimal version of GNUmakefile, may be it
will work.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
