[Gdal-dev] SVN problem
Howard Butler
hobu at iastate.edu
Tue Apr 10 10:35:37 EDT 2007
svn doesn't answer to /svn/gdal anymore.
svn switch --relocate http://svn.osgeo.org/svn/gdal https://svn.osgeo.org/gdal
should do the trick.
At 09:30 AM 4/10/2007, Thom DeCarlo wrote:
>When I try to do an svn update I get the following error:
>PROPFIND request failed on '/svn/gdal/gdal/!svn/vcc/default'
>'/svn/gdal/gdal/!svn/vcc/default' path not found
>Is anyone else having this problem?
>Thom
>this sig intentionally left blank
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
