[Gdal-dev] SVN problem
Thom DeCarlo
t.r.decarlo at larc.nasa.gov
Tue Apr 10 10:47:16 EDT 2007
Howard,
Thanks! That was all it took.
Thom
> -----Original Message-----
> From: Howard Butler [mailto:hobu at iastate.edu]
> Sent: Tuesday, April 10, 2007 10:36 AM
> To: Thom DeCarlo; GDAL developers
> Subject: Re: [Gdal-dev] SVN problem
> svn doesn't answer to /svn/gdal anymore.
> svn switch --relocate http://svn.osgeo.org/svn/gdal
> https://svn.osgeo.org/gdal
> should do the trick.
> At 09:30 AM 4/10/2007, Thom DeCarlo wrote:
> >When I try to do an svn update I get the following error:
> >PROPFIND request failed on '/svn/gdal/gdal/!svn/vcc/default'
> >'/svn/gdal/gdal/!svn/vcc/default' path not found
> >Is anyone else having this problem?
> >Thom
> >this sig intentionally left blank
> >_______________________________________________
> >Gdal-dev mailing list
> >Gdal-dev at lists.maptools.org
> >http://lists.maptools.org/mailman/listinfo/gdal-dev
