[Gdal-dev] Proposal for Unified Windows Binaries
Howard Butler
hobu at iastate.edu
Sun Apr 15 10:51:32 EDT 2007
All,
I think the time has arrived for us work toward releasing Windows
binaries that coincide with software releases. Numerous projects,
notably WorldWind, Python Cartographic Library, GeoTools/GeoServer,
and many others are starting to more widely take advantage of all the
hard work the swig bindings maintainers have been doing. There are
currently a number of folks generating Windows binaries, most notably
FWTools and MS4W.
From a user's perspective, it is almost impossible to mix and match
the drivers and features (scripting bindings, Python utilities, etc)
that you might need if you want to do anything out of the ordinary
for each distribution. Each distribution also has a very different
aim, with MS4W mostly tracking releases and FWTools covering the
bleeding edge. As a purveyor of exotic drivers (ArcSDE), the
different distributions makes it hard for me to provide support, even
though my driver can be built as a plugin, because of the need to
match up linkages against each distribution.
I think an "official" Windows GDAL release should have the following
traits:
- All optional drivers built as plugins and all other drivers built in
- No scripting bindings
- No Python utilities
- Include the .lib files
Instead of a monolithic kitchen sink approach, I think it might be
better to provide the basic building blocks, which will allow
developers to start from the same base and augment from that. For
example, with "GDAL Base," we could provide the Python bindings and
utilities as an installable package that targets each Python version
(same for .NET bindings, Java, and so on).
Thoughts?
Howard
