[Gdal-dev] Proposal for Unified Windows Binaries
    Ari Jolma
    ari.jolma at tkk.fi
    Sun Apr 15 13:36:54 EDT 2007
I've just spent numerous hours trying to get at least one of the
JPEG2000 drivers to work with MinGW built GDAL. I managed to compile the
ECW driver but linking was a too big pain since MinGW is not directly
supported. I also tried to to compile and link the Perl bindings in
MinGW to use the DLLs in FWTools. I ended up hacking dlltool, and I got
the thing almost working but ended up in a mysterious "illegal instruction".
Perhaps my problem is sticking with MinGW. If I switched to MS C I could
possibly use Perl (ActiveState) and other binaries.
Yes, the idea of being able to use (and tell others to use) a generic
GDAL windows installation package as a part of a bigger geospatial tool
system sounds good.
Ari
Howard Butler kirjoitti:
> All,
> I think the time has arrived for us work toward releasing Windows
> binaries that coincide with software releases.  Numerous projects,
> notably WorldWind, Python Cartographic Library,  GeoTools/GeoServer,
> and many others are starting to more widely take advantage of all the
> hard work the swig bindings maintainers have been doing.   There are
> currently a number of folks generating Windows binaries, most notably
> FWTools and MS4W.
> From a user's perspective, it is almost impossible to mix and match
> the drivers and features (scripting bindings, Python utilities, etc)
> that you might need if you want to do anything out of the ordinary for
> each distribution.  Each distribution also has a very different aim,
> with MS4W mostly tracking releases and FWTools covering the bleeding
> edge.  As a purveyor of exotic drivers (ArcSDE), the different
> distributions makes it hard for me to provide support, even though my
> driver can be built as a plugin, because of the need to match up
> linkages against each distribution.
> I think an "official" Windows GDAL release should have the following
> traits:
> - All optional drivers built as plugins and all other drivers built in
> - No scripting bindings
> - No Python utilities
> - Include the .lib files
> Instead of a monolithic kitchen sink approach, I think it might be
> better to provide the basic building blocks, which will allow
> developers to start from the same base and augment from that.  For
> example, with "GDAL Base," we could provide the Python bindings and
> utilities as an installable package that targets each Python version
> (same for .NET bindings, Java, and so on).
> Thoughts?
> Howard
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka
Geoinformation and positioning technology
Teknillinen Korkeakoulu / Helsinki University of Technology
POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
