[Gdal-dev] Re: Issue running Swig-Java gdalinfo
Daniel Siino
drsiino at gmail.com
Mon Apr 16 12:33:33 EDT 2007
Ok, I've found out what I was missing, thanks to a link in a previous post:
I've included the manifest to the ogrjni.dll by adding
mt -manifest ogrjni.dll.manifest -outputresource:ogrjni.dll;2
in the swig\java makefile.
Best regards,
Daniel
On 4/15/07, Daniel Siino <drsiino at gmail.com> wrote:
> Hi,
> I've build GDAL on Windows XP using nmake from VC++ 2005 express.
> I can run ogrinfo.exe without problems. However, after building the Java
> binding using Swig (swigwin-1.3.31), I ran the gdalinfo test class
> provided and got an error:
> Native library load failed.
> java.lang.UnsatisfiedLinkError: D:\ms4w\gdal\swig\java\gdaljni.dll: The
> specified procedure could not be found
> Exception in thread "main" java.lang.UnsatisfiedLinkError:
> org.gdal.gdal.gdalJNI.AllRegister ()V.
> I've searched the forum and looked at similar issues but was not able to
> correct it.
> The DLL is on my path and from the error message, it is being loaded.
> Is this an issue with the compiler messing up the name of the entry point
> by adding underscore?
> I've look at the dll using DependencyWalker and this is what I see:
> _Java_org_gdal_gdal_gdalJNI_AllRegister at 8
> Is this correct?
> As a side question, is the MITab format supported through the Swig Java
> binding?
> Regards,
> Daniel
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070416/6cbbdc5a/attachment.html
