[Gdal-dev] Re: Proposal for Unified Windows Binaries
Artur Redzko
artur.redzko at tatukgis.com
Mon Apr 16 03:25:16 EDT 2007
Ari Jolma napisał(a):
> Frank Warmerdam kirjoitti:
>> Generally speaking if you use the C API I *think* there should be
>> no cross-heap / cross-runtime problems but I'm not 100% sure of this
>> myself. I'm imagining shipping a core built with VC7.1.
> The current bindings use the C API but they also use the Colortable
> class C++ API. That may cause some problems when trying to use a GDAL
> DLL built with other compiler than what you are using.
Maybe that's why I have problems with using standard DLL and C API in Delphi.
>> I think if we build with VC7.1
> Where can one get (even buy) VC7.1 (aka Visual C++ .NET 2003)?
> My opinion is that the GDAL DLL binary package should be distributed as
> an end-users version and then there should be an associated developers
> package with include files and import libraries and/or DEF files.
That would be great. Other products using GDAL like openev change distributive dll-s requiring lots of additional stuff instead of one simple DLL.
> Best regards,
> Ari
>>So where do we go from here? Should we get Mateusz to prepare initial
>>binaries for 1.4.1 based on the suggested pattern?
Yes, please.
So when Mateusz can prepare initial binaries for 1.4.1, with version exporting C API without C++ stuff, so it can be easily used with Delphi (that doesn't like C++) ?
Pozdrowienia / Regards
AR
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070416/844a317c/attachment.html
