[Gdal-dev] Reading/Writing via GDAL library
Norman Vine
nhv at cape.com
Sun Apr 22 02:19:33 EDT 2007
Tommy Chheng writes:AL library
> I will be using the GDAL in conjunction with OSSIM, but for
> this error, I commented out the OSSIM-specific code and just
> ran the tutorial code.
> This is one of the errors that I'm encountering
> :C:/ossimcvs/ossimConsole/ship_detect.cpp:(.text+0x22):
> undefined reference to `OGRSFDriverRegistrar::Open(char
> const*, int, OGRSFDriver**)'
> I have gdal14.dll and I tried linking it using:
> -L/c/ossimcvs/gdal-1.4.0/lib -lgdal
> -L/c/ossimcvs/gdal-1.4.0/lib -lgdal14
> -L/c/ossimcvs/gdal-1.4.0/lib -l"gdal14.dll"
> All with the same error. Any ideas why it isn't linking correctly?
Tommy
Using the last example on http://www.gdal.org/ogr/ogr_apitut.html
The following commandline works for me with MingW in a MSYS shell
c++ `gdal-config --cflags` ogr_examp.c++ `gdal-config --libs` -o
org_examp.exe
Note the back ticks
HTH
Norman
