[Gdal-dev] RE: Reading/Writing via GDAL library
t chheng
tcchheng at ucsd.edu
Mon Apr 23 13:36:24 EDT 2007
Thanks, that does work.
I'm curious, why doesn't the compile options i've tried work? Why do i have
to use the libgdal.a rather than the produced gdal14.dll file?
> I have gdal14.dll and I tried linking it using:
> -L/c/ossimcvs/gdal-1.4.0/lib -lgdal
> -L/c/ossimcvs/gdal-1.4.0/lib -lgdal14
> -L/c/ossimcvs/gdal-1.4.0/lib -l"gdal14.dll"
Tommy
Norman Vine wrote:
> Tommy Chheng writes:AL library
>> I will be using the GDAL in conjunction with OSSIM, but for
>> this error, I commented out the OSSIM-specific code and just
>> ran the tutorial code.
>> This is one of the errors that I'm encountering
>> :C:/ossimcvs/ossimConsole/ship_detect.cpp:(.text+0x22):
>> undefined reference to `OGRSFDriverRegistrar::Open(char
>> const*, int, OGRSFDriver**)'
>> All with the same error. Any ideas why it isn't linking correctly?
> Tommy
> Using the last example on http://www.gdal.org/ogr/ogr_apitut.html
> The following commandline works for me with MingW in a MSYS shell
> c++ `gdal-config --cflags` ogr_examp.c++ `gdal-config --libs` -o
> org_examp.exe
> Note the back ticks
> HTH
> Norman
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/Reading-Writing-via-GDAL-library-tf3620307.html#a10145189
Sent from the GDAL - Dev mailing list archive at Nabble.com.
