[Gdal-dev] Computing MinMax on a NETCDF subdataset
Joaquim Luis
jluis at ualg.pt
Tue Apr 24 12:21:11 EDT 2007
Frank Warmerdam wrote:
> Joaquim Luis wrote:
>> Hi,
>> In my gdalread MEX file I have this call
>> GDALComputeRasterMinMax(hBand, FALSE, adfMinMax);
>> which, in case of reading a NETCDF file, is returning
>> adfMinMax[0] = 0 and adfMinMax[1] = 0
>> or
>> adfMinMax[0] = -4294967295.0 and adfMinMax[1] = 4294967295.0
>> if I change to
>> GDALComputeRasterMinMax(hBand, TRUE, adfMinMax);
>> Note that I'm using this (example)
>> Z = gdalread('NETCDF:"D:\SVN\global.nc":z');
>> which is the correct way of using this MEX, confirmed by the fact
>> that Z has the correct values.
>> For all other formats that I have tested, the min/max is correct.
>> Is this on purpose or a feature?
> Joaquim,
> This is not expected behavior. Could you provide the global.nc file
> for me
> to do some testing with?
Frank,
No need to use the global.nc. I reproduced the same behavior with a GMT
generated file.
e.g, using GMT's example 5 mexican hat you can use the sombrero.grd for
testing
grdmath -R-15/15/-15/15 -I0.3 X Y HYPOT DUP 2 MUL PI MUL 8 DIV COS EXCH
NEG 10 DIV EXP MUL = sombrero.grd
For sanity I rechecked with old format GMT file (e.g grdmath ... =
sombrero.grd=cf) and the result was correct
> Perhaps best to file this as a problem bug so I can keep track of it.
Done.
Joaquim
