[Gdal-dev] Incorrect adfGeoTransform on a NETCDF subdataset
Joaquim Luis
jluis at ualg.pt
Tue Apr 24 16:53:48 EDT 2007
Hi again,
Now the problem is with adfGeoTransform.
adfGeoTransform[3] and adfGeoTransform[5] have the sign swapped on a
NETCDF dataset.
Without checking how GDALInfoReportCorner() works I think that the
problem is illustrated
with the following example
Cheers
Joaquim Luis
Use GMT to create two example files
grdmath -R-10/15/-9/16 -I1 = t1.grd ------ netCDF file
grdmath -R-10/15/-9/16 -I1 = t2.grd=cf ------ old GMT format file
gdalinfo t2.grd
Driver: GMT/GMT NetCDF Grid Format
Size is 26, 26
Coordinate System is `'
Origin = (-10.500000000000000,16.500000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Corner Coordinates:
Upper Left ( -10.5000000, 16.5000000)
Lower Left ( -10.5000000, -9.5000000) --------------->
CORRECT
Upper Right ( 15.5000000, 16.5000000)
Lower Right ( 15.5000000, -9.5000000)
Center ( 2.5000000, 3.5000000)
Band 1 Block=26x1 Type=Float32, ColorInterp=Undefined
gdalinfo NETCDF:"t1.grd":z
Driver: netCDF/Network Common Data Format
Size is 26, 26
Origin = (-10.500000000000000,-9.500000000000000)
Pixel Size = (1.000000000000000,1.000000000000000)
Metadata:
NC_GLOBAL#Conventions=COARDS
NC_GLOBAL#history=grdmath -R-10/15/-9/16 -I1 = t1.grd
NC_GLOBAL#node_offset=0
z#long_name=z
z#_FillValue=1.#QNAN0e+000
z#actual_range=0.000000e+0000.000000e+000
x#long_name=x
x#actual_range=-1015
y#long_name=y
y#actual_range=-916
Corner Coordinates:
Upper Left ( -10.5000000, -9.5000000)
Lower Left ( -10.5000000, 16.5000000)
Upper Right ( 15.5000000, -9.5000000)
------------------> WRONG
Lower Right ( 15.5000000, 16.5000000)
NoData Value=1.#QNAN
Metadata:
NETCDF_VARNAME=z
