[Gdal-dev] gdaladdo errors on Linux
William Kyngesburye woklist at kyngchaos.com
Wed Apr 25 18:13:32 EDT 2007
I've had similar problems before and it's a problem with the libtiff
version.  Fixes for part of the problem are in libtiff CVS (and are
included in my OSX frameworks).  It also was less of a problem in
earlier libtiff versions (3.6, 3.7), but there may still be issues.
This looks slightly different than what I've seen before so it might
not help, but it's worth a try.
On Apr 25, 2007, at 4:41 PM, Richard Greenwood wrote:
> I've got an odd situation. I have a set of TIFFs that I can add
> overlays to under Windows and Mac OS X, but not Linux.
> The gdaladdo error under Linux is:
> ERROR 1: IReadBlock failed at X offset 2, Y offset 4
> ERROR 1: GetBlockRef failed at X block offset 2, Y block offset 4
> ERROR 1: F43110A1.TIF:DumpModeDecode: Not enough data for scanline 256
> ERROR 1: TIFFReadEncodedTile() failed.
> (These 4 error repeat "forever")
> The images are 8 bit TIFFs with a 13 color table. The Linux and OS X
> versions of gdaladdo are identical (1.3.2.0) the Windows version is
> 1.4.0.0. I have run gdaladdo on the Linux box successfully in the
> past.
> It seems like it's unable to read the files. The permissions look okay
> (-rw-rw-r--) and I'm the owner.
> I feel like I'm missing something obvious. Any suggestions?
> Thanks,
> Rich
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
