[Fwd: [Gdal-dev] Nodata bitmasks / null processing]
guillaume huby
guillaume.huby.lists at gmail.com
Mon Aug 6 03:48:54 EDT 2007
> -------- Message original --------
> Sujet: [Gdal-dev] Nodata bitmasks / null processing
> Date: Sat, 04 Aug 2007 13:06:04 -0400
> De: Frank Warmerdam <warmerdam at pobox.com>
> Pour :: gdal-dev <gdal-dev at lists.maptools.org>
> Folks,
> Currently GDAL supports two mechanisms for identifying nodata/transparent
> areas in a raster. One is use of a particular pixel value as a nodata
> value (returned by the GDALRasterBand::GetNodataValue() method) and the
> other
> is by specifying an alpha band with alpha=0 marking transparent areas.
> However, a number of file formats support a concept of "nodata masks" -
> essentially bitmasks marking areas of the raster that are nodata
> areas. But
> this is accomplished without having to reserve a special marker value to
> be
> the nodata value.
> I am looking for some feedback from the community. In particular I'm
> interested in examples of file formats that include bit masking.
Frank,
I'm not sure being able to say you what is the best way to implement this.
But I can say that this is an interesting project. I can provide you a
sample I would like to see implemented. MODIS HDF files are all provided
with a Quality Assurance bit mask. For exemple you can take surface
reflectance files (http://edcdaac.usgs.gov/modis/myd09gqv5.asp, there is
download links in this page). These files have two datasets for surface
reflectance (http://edcdaac.usgs.gov/modis/myd09gqv5_sds.asp) and one for
Quality Assurance (http://edcdaac.usgs.gov/modis/qa/myd09gq_qa_v5.asp). I
think that your project can be very usefull in this case.
I hope this will help you !
Best regards,
Guillaume.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070806/29150f31/attachment.html
