[Gdal-dev] DOS crlf in GDAL create() ?
Frank Warmerdam
warmerdam at pobox.com
Mon Aug 6 15:55:07 EDT 2007
Dave Favis-Mortlock wrote:
> Hi -- is it possible to force DOS crlf end-of-lines when GDAL create() writes
> ascii metadata files?
> I ask because I'm writing Idrisi output on Linux (where end-of-lines are, of
> course, lf only). Idrisi (running under WINE) expects DOS crlf end-of-lines
> in its .rdc metadata files.
> OK, I can write my .fdc files then convert 'em using unix2dos, but it would be
> nice to avoid this step. I see that OGR uses a LINEFORMAT switch for .csv
> files. Anything similar for GDAL?
Dave,
There is no generic support for this, but it could potentially be addressed
on a driver by driver basis - or if IDRISI doesn't exist on Linux, perhaps
we should just always be writing these files with DOS text format? I'd
encourage you to file a bug on it, and we will see what Ivan says about it.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
