[Gdal-dev] Quickly generating Google Earth files
Christopher Condit
condit at sdsc.edu
Wed Aug 8 09:45:38 EDT 2007
Hi Jose-
There isn't anything that I know of to accomplish this presently, but you could probably cook something up fairly easily to parse a world file and generate a simple KML file pointing to the raster. Just remember that Google Earth wants EPSG:4326 so if your raster is in some other projection you'll have to warp the coordinates accordingly...
-Chris
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Jose Luis Gomez Dans
Sent: Monday, August 06, 2007 12:21
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Quickly generating Google Earth files
I know there's a GSoC project dealing with a full-fledged GDAL KML driver. I take it that this will enable to quickly publish things like the datasets shown in <http://www.kcl.ac.uk/schools/sspp/geography/research/emm/geodata/>.
We have heaps of raster-based information, and it would be interesting to see if we can serve it through a kmz file, as in the examples above. While I understand the new driver will allow that sort of thing, I was wondering whether it is possible to do something similar as of today, with a current version of GDAL.
Any hints or comments?
Cheers!
Psssst! Schon vom neuen GMX MultiMessenger gehört?
Der kanns mit allen: http://www.gmx.net/de/go/multimessenger
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
