[Gdal-dev] int64 support?
Christopher Barker
Chris.Barker at noaa.gov
Fri Aug 10 12:26:55 EDT 2007
Vincent Schut wrote:
> Not really necessary, but it would be convenient if gdal supported
> (u)int64 data... Using numpy on my amd64 linux pc, when I create a numpy
> array without specifying the datatype it defaults to int64, which gdal
> refuses to save. Usually an 'astype(int32)' suffices, but still it is a
> bit annoying sometimes.
hmm this isn't a very compelling argument to me.
The question is: Do you have a need to create/read (u)int64 data?
If there is a need for that, then it may be worth supporting, but if
it's only about the defaults of numpy -- that should be addressed
elsewhere: either in your code or in numpy itself, which brings me to:
> array without specifying the datatype it defaults to int64.
First, that's int64, not uint64 -- is there any need for uint64?
Second -- how are you creating your arrays? Many of the array
constructors default to float64 now. However, what I suspect is that you
are creating arrays from python integers, in which case numpy will (or
should!) default to the same datatype as a python integer, which is
apparently int64 on amd64 Linux.
Anyway, it's always a good practice to specify the data type when
creating an array that's going to interact with any outside package. The
numpy developers have made a substantial effort to keep accidental
upcasts from happening with operations with python numbers:
>>> import numpy as N
>>> a = N.ones((3,3), dtype=N.int16)
>>> a.dtype
dtype('int16')
>>> b = a * 5
>>> b.dtype
dtype('int16')
(I'm on a 32bit machine, so I used int16 as my example)
So you should be OK if you create them as int32 to start with.
When writing a function that requires a particular data type, it's very
handy to start it out with something like:
def CreateGDALSomething(InputArray):
InputArray = N.asarray(InputArray, dtype=N.int32)
asarray() will be a no-op if the input array is already the right type.
As a rule, whenever you are creating GDAL object, you should know what
kind of file you're creating, and that includes the datatype.
In short -- if you follow numpy and GDAL best practices you shouldn't
have a problem.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
