[Gdal-dev] Re: Coordinate to pixel space? (C#)
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 23 09:26:52 EDT 2007
Tomas R wrote:
> Tomas R skrev:
>> This I should have asked a long time ago.
>> Can GDal give me a translation from the maps coordinate space to/from
>> pixel space? That is if I Gdal has a dataset of a map with known
>> projection and known edge coordinates.
>> As simple as that.
>> /Tomas
> I missed a bit of data above. The real question is if it is possible to
> get the the pixel coordinate given a projection and map data (edge
> coordinates, resolution) of a given coordinate in projection space when
> using Gdal with the C# bindings? If there exists a function which can
> do this?
> And vice versa. If I have a pixel in the map, can I call a function
> which gives me the coordinates in projection space for that pixel?
> Ok, perhaps not so hard to implement myself but still, why do it if Gdal
> can?
Tomas,
Pixel locations and georeferenced coordinates are normally related by the
affine "GeoTransform" that can be fetched using the GetGeotransform()
method on a GDALDataset.
It's use is discussed briefly in the section labelled "Affine GeoTransform"
in the data model document:
http://www.gdal.org/gdal_datamodel.html
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
