[Gdal-dev] Re: Coordinate to pixel space? (C#)
Tamas Szekeres
szekerest at gmail.com
Thu Aug 23 08:13:35 EDT 2007
Tomas,
If I understand correctly your request might be the same as described in
http://trac.osgeo.org/gdal/ticket/1531
Currently you should perhaps do the affine transformation manually
using the coefficients retrieved by GetGeoTransform.
Best regards,
Tamas
2007/8/23, Tomas R <monshi at home.se>:
> Tomas R skrev:
> > This I should have asked a long time ago.
> > Can GDal give me a translation from the maps coordinate space to/from
> > pixel space? That is if I Gdal has a dataset of a map with known
> > projection and known edge coordinates.
> > As simple as that.
> > /Tomas
> I missed a bit of data above. The real question is if it is possible to
> get the the pixel coordinate given a projection and map data (edge
> coordinates, resolution) of a given coordinate in projection space when
> using Gdal with the C# bindings? If there exists a function which can
> do this?
> And vice versa. If I have a pixel in the map, can I call a function
> which gives me the coordinates in projection space for that pixel?
> Ok, perhaps not so hard to implement myself but still, why do it if Gdal
> can?
> Yours
> Tomas
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
