[Gdal-dev] Re: [GDAL] #913: NITF driver fails for some CADRG tiles
Even Rouault even.rouault at mines-paris.org
Mon Aug 27 19:03:07 EDT 2007
Sophia,
thanks for testing the fix for bug #913.
What's annoying is that I've just tested your file and it works fine with the
svn version of GDAL trunk (as well as a version of GDAL 1.4.2 that I've
patched). Just out of curiosity, I've removed the fix for bug #913 and
another CADRG bug I've fixed, and your file is still working fine...
Even more, it is still working fine with the official GDAL 1.4.2 release. Are
you really sure you're linking with the good GDAL library ?
I can't see other explanations for the moment.
Your first message said that the bbox displayed was not correct. I get the
following results with GDAL svn trunk :
Corner Coordinates:
Upper Left  ( 160.3951807,  59.5397891) (160d23'42.65"E, 59d32'23.24"N)
Lower Left  ( 160.3951807,  59.0220518) (160d23'42.65"E, 59d 1'19.39"N)
Upper Right ( 161.4361446,  59.5397891) (161d26'10.12"E, 59d32'23.24"N)
Lower Right ( 161.4361446,  59.0220518) (161d26'10.12"E, 59d 1'19.39"N)
Center      ( 160.9156627,  59.2809204) (160d54'56.39"E, 59d16'51.31"N)
Best regards
On Monday 27 August 2007 19:52:21 you wrote:
> Even,
> I rebuilt gdal with the patch but I get an error with the attached
> file.  Here is the error I get:
> ERROR 3: Unable to read 6144 byte block from -16705196.
> ERROR 1: IReadBlock failed at X offset 1, Y offset 3
> I've attached the file, it is a tile from a CADRG cd.
> Thanks,
> sophia
> Even Rouault wrote:
> > Sophia,
> > I don't know what your exact problem was, but bug #913 has just been
> > fixed in GDAL trunk subversion repository and will be available in GDAL
> > 1.5.
> > See http://trac.osgeo.org/gdal/ticket/913.
> > Could you check if it also solves your problem ? Thank you.
> > Best regards,
