[Fwd: [Gdal-dev] RFC 15: More Band Masks]
guillaume huby guillaume.huby.lists at gmail.com
Tue Aug 28 03:05:49 EDT 2007
Hi Frank,
   http://trac.osgeo.org/gdal/wiki/rfc15_nodatabitmask
If I do not misunderstood, you wrote that mask should be of type GDT_Byte.
Why limit to GDT_Byte ? For exemple MODIS QA bands can be of type GDT_UInt16
(http://edcdaac.usgs.gov/modis/qa/mod09gq_qa_v5.asp). I know that you are
not implementing HDF yet, but if you do it in a future, you might have to
make changes to allow this. I recognize that this is a very specific case
and is not necessary for the first purposes of your project.
Thanks for your great work,
Guillaume.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070828/563a242f/attachment.html
