[Gdal-dev] loading metadata into NITF from separate image format
Jared Rubin JARED.RUBIN at saic.com
Fri Aug 31 19:51:40 EDT 2007
I am inheriting from the RawDataset because it is scan line orientated and
would like to stuff metadata like sensor zenith, sun azimuth, etc.. that are
well defined metadata items in NITF and TIFF so that I can convert an
internal image format to NITF or TIFF. Is there a specific domain that I need
to use for NITF or TIFF for stuffing the metadata. If so can someone provide
an example?
   In addition, if i was to stuff the metadata to NITF, would it carry over to
TIFF?
Basically if run gdal_translate from my internal format to NITF and then run
gdal_translate from NITF to TIFF would the metadata carry over to TIFF?
Thanks
Jared
