[gdal-dev] SDE raster driver: vertical displacement of 64 pixels
Duarte Carreira DCarreira at edia.pt
Wed Dec 5 09:51:36 EST 2007
Hello all.
I've just tested gdal's sde driver to export a geographic window from a
ArcSDE raster dataset, using the -projwin option. I tested against
ArcSDE 9.2 SP3, on Oracle 92, using FWTools 1.3.9 containing GDAL
1.5dev.
I measured the distance between the original and the exported image and
got 64 pixels vertical, 0 horizontal.
The raster dataset is 0,4m / pixel, and the raster tile dimension is
128x128 pixels. Could it be something to do with the tile size? But
128x128 is the default value.
This is the same problem I reported a few months back.
Any possible help on this?
Regards,
Duarte Carreira
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071205/1e5928f8/attachment.html
